Shutdouwn Python Script : Move file from work directory to another directory
  • September 13, 2013
  • 15 views
farfar
Forum|alt.badge.img+11
Hi all,
I need to move my Reader file (toto.shp.zip)  from its location to another directory after traitment. I think the best way to do it is into Shutdown python script. But i can't find the code to do it. Could some one to help me?
Thanks an advance.
Farfar
fmelizard
Forum|alt.badge.img+18
Another option would be to call a file copy reader in a second ws via the workspacerunner.
Hope this helps,
Itay
  • September 14, 2013
Hi Farfar,
If you want to move the file with a Python script, os.rename function can be used:
# Example import os   # target file name and source path file = 'toto.shp.zip' src = 'C:/tmp/src/' + file   # destination directory and dest. file path dir = 'C:/tmp/dest' dest = '%s/%s' % (dir, file)   if os.path.exists(src):     # if dest. file exists already, remove it.     # else if dest. directory does not exist, create it.     if os.path.exists(dest):         os.remove(dest)     elif not os.path.exists(dir):         os.makedirs(dir)          # rename (move) the source file     os.rename(src, dest)
See more information about os module here:
15.1. os — Miscellaneous operating system interfaces
http://docs.python.org/2.7/library/os.html#module-os
Takashi
farfar
  • June 4, 2014
Hi All,
I need to retrieve a path of writer to remove this writer file from its directory to another one. i use Takashi example below but i couldn't retrive the writer path using Shutdown Python Script.
Any idea?
Thanks an advance.
Farfar
