Shp to DWG, how to draw order layers?
  • May 5, 2020 9:50 PM UTC
  • 218 views
I'm converting different shapefiles to 1 DWG. How can I set the draw order of the layers in Autocad automatically with FME?
Thanks!
Regards,
Pieter
becchr
Forum|alt.badge.img+35
  • May 5, 2020 10:05 PM UTC
hi @pietervb94, as far as i know the order in the dwg is defined by the order of the objects reaching the writer (last object on top). You could try holding/sorting your features to get the desired result, depending on how complex your data is...
There's an (old) idea you could vote on to get more control on drawing order:
https://knowledge.safe.com/idea/47427/format-attributes-for-autocad-drawing-order.html
verdoodtdries
Forum|alt.badge.img+23
Add a Sorter before the FeatureWriter to sort the Features by layer. FME Format attribute: autocad_layer.
