shp 2D to create with many folders in source (static is possible?)
  • July 24, 2013
  • 5 views
My problem is that I have many files to convert with differents attributs and a static shema seems to be not avalaible (lost of attributs).
It's very important to me to solve this problem and i work to solve it but with no success.I think it's a hard case.
To understand my problem here is the link of my whole MIF data to convert :
https://docs.google.com/file/d/0B90n7rx5ph0ZaXZXZ21RNUh1WkE/edit?usp=sharing
Now how to obtain :
R120_1-1_SHP_LAMB93_FR-ED121 with all the SHP 2D in the same folder than source.( I know how to do that but only in dynamic shema)
thank you
  • July 24, 2013
It is most likely a bug in FME, you should send the issue to either your FME reseller (Veremes?) or directly to Safe support.
David
