Shapefile with cst encoding spec (from GeoServer)
  • Aug 22, 2024 11:09 AM UTC
  • 0 replies
  • 181 views
nordpil
Forum|alt.badge.img+12
When exporting to shapefile from GeoServer/WFS one can specify encoding in the request, for my case I specified UTF-8.
This shapefile has a cst-file that establishes the encoding (similar to cpg from ArcGIS).
When I read this in Workbench/Server 2022.2 the fields have encoding cp-1252 and some garbled characters. If I change the filename to from cst to cpg the attributes come in with the correct encoding.
Is this fixed in later versions, or should it be reported as a bug… ?
