Shapefile Attribut gets mysteriously to many characters, can't join or merge
  • Apr 13, 2018 3:05 PM UTC
  • 86 views
chrishoh
I'm trying to join a Shapefile to another table, but it fails.
The joining attribute(encoded: utf-8) has value "41400562015" but during the prozessing it becomes "41400562015????????????????????????"
I tried to change the attributetype of both fields into different types, including integer or varchar (12) - but the resulting string is still longer than 12 digits?... I also tried to calculate the string (left 12) into a new attribut or to use the trim-funktion. Nothing works?
not to be misleading: the original connection attribute on both sides is a textstring like "BT-4209-0001-2018". No blancs.
But the joining failed and i detected something like
"BT-4209-0001-2018 ___________ " with empty spaces at the end
Because the connection with strings did not work, i changed it into numbers, so joining in FeatureMerger or InlineJoiner should be .
(I have done the same connections thousands of times, these
difficulties with shapes are only occurring sometimes and are quite new (FME2017)
fmelizard
Forum|alt.badge.img+22
  • Apr 13, 2018 10:27 PM UTC
Hi @chrishoh Please send us your workspace and some sample data via www.safe.com/support Thanks!
chrishoh
  • Apr 18, 2018 12:19 PM UTC
seems to be an issue with the dBase-tables. Some shapes work, some don't. When exporting these non-working shapes into new shapes in ArcGIS - these new shapes will work. But I cannot detect any change in the attributformats.
strange, stupid old dbase-tables....
gio
Forum|alt.badge.img+15
  • Apr 18, 2018 4:02 PM UTC
remove non utf8 characters?
Or remove tabs with stringreplacer.
