I’m combining lines based on end noded while keeping some attributes in a list for each original lines (1). Then I create a new attribute based on the lists (2) with conditions based on numbers in the lists (3).
I would like to set up the condition statement dynamically: the number of lists varies each time I run the workflow so I would like to pick numbers from the last list available (in this case PR_list{2}) and do something like: PR_list{0}.ORIGINE < PR_list{max}.ORIGINE instead of choosing the list manually.
Is it possible to create a dynamic condition in the condition value definition?
