setting excel row colour
  • January 14, 2015
  • 102 views
jdh
Forum|alt.badge.img+40
Hi all,
Is there a way to set the colour (background or text) of a row in excel based on an attribute value?
I would like to be able to highlight certains rows in the file based on whether they passed or failed validation.
fmelizard
Forum|alt.badge.img+21
  • January 15, 2015
I dont think there is a way to it via an attribute value.  You could alternatively use different writer feature types that will result in different tabs.
  • January 15, 2015
I can't think of a way to do this in FME but in Excel you can colour cells or entire rows based on a condition. Navigate in Excel to the Home tab, Styles group, and choose Conditional Formatting > New Rule....
jdh
  • January 15, 2015
Unfortunately I'm already using different tabs for other reasons.  I was hoping to avoid having to make any changes in the excel file post process.
gio
Forum|alt.badge.img+15
  • January 15, 2015
...you can try using python to do that.
from win32com.client import Dispatch
import os
etc.
There are sample codes out on the net.
