Setting DB namespace dynamically from SourceDataset_GENERIC through RegexReplacement
  • Apr 25, 2018 5:28 AM UTC
  • 13 replies
  • 122 views
dollargis
I want to set the PostGIS namespace dynamically, derived through a RegExp from the SourceDataset_GENERIC parameter, however all my imports end in the 'public' namespace.
Best answer by takashi
In my quick test, as well as the workaround for SQL Server, this dynamic schema setting worked as expected. Assuming that the destination schema name is given as a user parameter called $(SCHEMA).
$(SCHEMA).@Value(fme_feature_type)
Naturally the database should have the schema beforehand. If the schema could be missing when you run the workspace, you could create it with this SQL statement set to the "SQL To Run before Write" parameter in the writer.
create schema if not exists $(SCHEMA)
dollargis
  • Apr 25, 2018 5:29 AM UTC
vector-import-worker.fmw
This is how I try to achieve my goal currently
lars_de_vries
Forum|alt.badge.img+10
I have looked at your workspace and you need to remove the double quotes from the last to parts of the @ReplaceRegEx statement, making it look like this:
@ReplaceRegEx($(SourceDataset_GENERIC),^.*[\\/](rgu|gsm)[\\/].*$,\1)
dollargis
  • Apr 25, 2018 6:18 AM UTC
@lars_de_vries: Thanks for the fast answer. I modified the regex accordingly and removed the unneccessary transformers.
Unfortunately it still doesn't work:
My input is '/tmp/gsm/t/stadtplan_bildung.gpkg' , so the regex should extract 'gsm' and set this as the namespace for the new table.
But the table ist still created in public.
16612-vector-import-worker.fmw
16612-vector-import-workerlog.txt
dollargis
  • Apr 25, 2018 6:45 AM UTC
Further exploration shows that the Regex is now correct, but in dynamic mode FME 2018 seems to still carry this old bug:
https://knowledge.safe.com/questions/3478/postgis-schema.html
Could someone please verify this?
lars_de_vries
Looking at the workspace, there are two suggestions I could make:
1. Does it help if you create an attribute first containing the namespace? And
2. How about creating a second writer and set the first Writer to 'rgu' as a namespace and the second to 'gsm' as a namespace. You could use a TestFilter to define which Writer should be used. It makes the process a little less dynamic, but allows to hardcode the namespace which could be a workaround for now.
dollargis
  • Apr 25, 2018 7:37 AM UTC
Thanks for the suggestions, @lars_de_vries
Unfortunately I am still struggling using the dynamic writer to PostGIS and setting any, even static namespace.
Whatever I try, the tables end up in 'public', which is where they do not have to go.
vector-import-worker.fmw is what I have now with an AttributeCreator setting the namespace to the string 'rgu', but it does not get honored.
I tried to create a fully qualified tablename like 'rgu.stadtplan_bildung', but I did not succeed in concatenating a string with the _fme_feature_type variable.
lars_de_vries
You could try this workspace, it is what I ment with my second suggestion.
16613-16612-vector-import-worker-2.fmw
dollargis
  • Apr 25, 2018 9:01 AM UTC
Thanks again, @lars_de_vries
Logic would say that this works, albeit the table fell again into 'public'.
Here is the log: 16617-16613-16612-vector-import-worker-2log.txt
lars_de_vries
I am sorry to hear that. I think I am a bit out of options here.
Maybe @FMELizard can tell whether this still is a unsolved bug as you suggested earlier, or something else is going on.
  • Apr 25, 2018 10:07 AM UTC
Hi @dollargis, I'm not sure if it is common to PostgreSQL/PostGIS writer, there was a similar issue before: "Dynamic" output to SQL Server - no Table Qualifier/database schema ?
dollargis
  • Apr 25, 2018 12:27 PM UTC
The problem lies in the combination of dynamic schema creation and any other namespace than 'public'. It seems impossible to get both
  • Apr 25, 2018 3:01 PM UTC
dollargis
  • Apr 26, 2018 6:40 AM UTC
Thanks, Takashi - this really solved my problem.
Now I am just scratching my head why I couldn't find this in the docs....
