SENTINEL2 reader
  • November 30, 2018
  • 14 views
I try to open an XML file downloaded with the SentinelDownloader
but I get this error:
Loaded module 'SENTINEL2' from file 'C:\\Program Files\\FME\\plugins/gdal/GDAL.dll'
FME API version of module 'SENTINEL2' matches current internal version (3.8 20180604)
SENTINEL2 reader: Opening dataset 'C:/4-Igual que 3 pero bajando ALL/all/S2A_MSIL2A_20181103T111221_N0209_R137_T30TVK_20181103T122857.SAFE/MTD_MSIL2A.xml'
SENTINEL2 reader: Cannot find =Level-2A_User_Product.General_Info.L2A_Product_Info
SENTINEL2 reader: Failed to open the dataset 'C:/4-Igual que 3 pero bajando ALL/all/S2A_MSIL2A_20181103T111221_N0209_R137_T30TVK_20181103T122857.SAFE/MTD_MSIL2A.xml'. Please ensure source data is valid and correct reader is selected
Failed to obtain any schemas from reader 'SENTINEL2' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
FME Session Duration: 0.1 seconds. (CPU: 0.1s user, 0.0s system)
END - ProcessID: 7936, peak process memory usage: 49232 kB, current process memory usage: 38416 kB
Program Terminating
Translation FAILED.
Workspace generation failed. Parameter file was C:\\Users\\JARFER~1\\AppData\\Local\\Temp\\FME_1543572203148_2116.
What can I do for opening it?
Thanks!
Best answer by xiaomengatsafe
Hi @deckard, It appears that the sentinel 2 reader supports the Level 1C product. Could you please download that and give it a try? This can be specified in the SentinelDownloader transformer.
xiaomengatsafe
Forum|alt.badge.img+3
  • December 4, 2018
  • December 26, 2018
The sentinel 2 reader supports the Level 1C product. Try reinstalling.
192.168.0.1
  • January 8, 2019
Thanks! I was trying to open a Level2A product! :P
