Scale factor on COG
  • Jul 7, 2025 1:58 PM UTC
  • 9 replies
  • 196 views
jdh
Forum|alt.badge.img+41
I have a COG with a scale factor (excerpt from GDALInfo)
Band 1 Block=1024x1024 Type=Int32, ColorInterp=Gray
  Min=-50313.000 Max=57304.000
  Minimum=-50313.000, Maximum=57304.000, Mean=4745.177, StdDev=7550.452
  NoData Value=-32767
  Offset: 0,   Scale:0.1
How do I apply this scale factor in FME?   If I clip the input and create a new tif,  the scale factor is dropped and the values are 10 times the expected.
In this particular case I can just scale the value back down, but in general, is there a way to retrieve the scale factor and apply it?
Best answer by crystalatsafe
Hi ​@jdh
Thank you for your patience!
The GeoTIFF Reader can now expose scale and offset factor in Format Attributes, please install the latest version of FME 2026.1 at: safe.com/downloads/
geomancer
Forum|alt.badge.img+71
  • Jul 7, 2025 2:38 PM UTC
Untested, as I don't have a COG at hand, but the documentation mentions
geotiff_exif_digitalzoomratio Represents the digital zoom ratio when the image was shot. If the numerator of the recorded value is 0, this indicates that digital zoom was not used.
Hopefully this attribute is related to the scale GDALInfo mentions.
jdh
  • Jul 7, 2025 3:12 PM UTC
I just checked and the geotiff_exif_digitalzoomratio tag is not populated.
geomancer
  • Jul 7, 2025 3:14 PM UTC
That's a pity...
crystalatsafe
Forum|alt.badge.img+32
Hi ​@jdh
I don't believe FME currently supports scale factors in GeoTIFF.
I have submitted an internal ticket for our development team (internal reference: FMEENGINE-87393) to explore the possibility of implementing this. I will make sure to update you on the progress.
jdh
  • Jul 15, 2025 6:58 PM UTC
Hi ​@jdh
Even an interim solution where the scale factor can be retrieved as metadata would be a useful step forward.
crystalatsafe
Hi ​@jdh
Can you please share your workspace and a sample dataset
jdh
  • Jul 17, 2025 5:00 PM UTC
​@crystalatsafe   The dataset is from https://zenodo.org/records/15689805    The workspace was just a Shapefile reader (AOI) → featureReader (clip to Initiator Envelope) → COG Writer
crystalatsafe
Hi ​@jdh
I'm sorry for the late response!
While our development team continues to look into this, you could try embedding an external tool or Python into Form.
Perhaps a library like this may be able to extract metadata, such as scale factor: https://pypi.org/project/tifftools/
crystalatsafe
  • Mar 26, 2026 10:10 PM UTC
Hi ​@jdh
