save Geometry to a jpg file
  • Feb 21, 2025 8:28 AM UTC
  • 121 views
fme_hans
Hi,I read sdo_geometry and make a cutout of a small area. I want to save this cutout as a jpf file. Is that possible?I do see jpg writers, but I suspect that some preparation needs to be done before you can save geometry data as jpg.
koulsoum
Forum|alt.badge.img+14
  • Feb 21, 2025 8:41 AM UTC
Hi ​@fme_hans you can use the Transformer ImageRasterizer and choose the cellspace you want. If you have to write several images you can use the group by mode
nielsgerrits
Forum|alt.badge.img+67
As an alternative you can use the MapnikRasterizer, you can then also overlay the vectordata with a reference image.
fme_hans
  • Feb 21, 2025 9:26 AM UTC
How to set the color for the Imagerasterizer? Ik get this error: INVALID_VECTOR_GEOMETRY_COLOR
In the reader i have checked fme_color and fme_fill_color.
I am testing with one polygon which comes from an Oracle spatial reader.
edit: found something: FeatureColorSetter
