Save a csv to SharePoint
  • September 21, 2021
  • 75 views
jackyd
Forum|alt.badge.img+12
I have a task where I need to extract data from a database and save it as a csv in SharePoint
I had hoped to b able to specified the path to the SharePoint folder in the csv writer, but this does not seem to work.
The error I get is
  • CSV writer: Failed to open file 'HTTP:\\\\projectzone.tnad.tasnetworks.com.au\\business-projects\\iap\\TE\\HVDC Cable Specifications\\SATVUE_99021037_2021_08.csv' for writing. Please ensure that you have sufficient privileges to write this file. If the file already exists, please ensure it is not open in another application
I am using FME Server and the FME Server service account has permission to write to this location.
JennaKAtSafe
Forum|alt.badge.img+8
Hi @jackyd​ , would you be able to confirm what version of FME Desktop/Server you are using?
I would also suggest following this guide to ensure the SharePoint connection is made correctly https://community.safe.com/s/article/How-to-create-a-Sharepoint-Web-Connection
jackyd
  • September 22, 2021
Hi Jenna,
we are using 2021.0.0.1 for both
I have looked at the web connection and not sure if it applies as we are using an inhouse hosted SharePoint and not web based.
I'll have a chat to our IT peeps and see what they sat though
Thanks
Cheers
Jacky
