Salesforce Writer Issue???
  • May 22, 2021 8:00 PM UTC
  • 7 replies
  • 117 views
crowleyb
Forum|alt.badge.img+4
I have a Salesforce custom object with 2 master-detail fields that both have read/write permissions. When I attempt to write to this object, I receive the "REQUIRED_FIELD_MISSING:Required fields are missing:" error. The two fields referenced are the 2 master-detail fields. The fields and the data are present when the write occurs but for some reason I receive this error. Any ideas?
Best answer by chrisatsafe
Screen Shot 2021-05-26 at 10.25.39 AM
Interesting, okay thanks for digging into that a bit more. I'm going to convert this thread to a case so our support team can investigate this and report it to our development team as a bug. Thanks for bringing this to our attention.
chrisatsafe
Hi @crowleyb​ ,
Are you using an automatic, manual, or dynamic attribute definition? Additionally, can you confirm that the field names in the writer feature type match the API name for the fields in the Salesforce Object Manager?
crowleyb
  • May 25, 2021 5:43 PM UTC
Thanks @chrisatsafe​. I actually added the reader to the workspace so I could use the copy from reader option to add the writer. So, the API names for the fields do appear correctly
crowleyb
  • May 26, 2021 2:21 PM UTC
@chrisatsafe​ - I was able to successfully use the data loader to my custom object. It appears the issue is the Salesforce writer does not recognize the external IDs (the related objects) I've established for the 2 Master-Detail data types I'm using. When using data loader, I have the ability to select the relationship (see attached images). I think that is the problem. The FME Salesforce writer does not recognize the external IDs or in the UPSERT setting options, I'm not referencing them properly.Screen Shot 2021-05-26 at 10.18.44 AMScreen Shot 2021-05-26 at 10.16.33 AM
crowleyb
  • May 26, 2021 2:25 PM UTC
chrisatsafe
  • May 26, 2021 3:24 PM UTC
crowleyb
  • May 26, 2021 4:28 PM UTC
Great. Thank you.
tyricores
  • Nov 11, 2021 9:05 AM UTC
You can try another platform when working with Salesforce. I see that your problem has already been solved here, in general I can just advise a good software when working with it, it`s revenue intelligence software. Here you can quickly get information all the analytics data that`s connected with transactions. Moreover, the statistics cover all the tools which you work with (social networks, mail, etc.). All settings can be customized As far as my experience is concerned - I`ve been using the platform for over a year now, so can confidently talk about its strengths.
