Run trigger with hstore function on writing
  • Mar 28, 2023 2:33 PM UTC
  • 75 views
albinepro
Forum|alt.badge.img+7
I would like to insert to a Postgres table where ther is set up an trigger event with hstore function to write to another table. While running in common SQL client with "public" search_path, there is no problem.
I can't make it run in FME workspace, always getting an error:
ERROR:  function hstore(vfk.par) does not exist
where "vfk.par" is the table I'm writing to. I have tried to add search_path "public" setup in "SQL To Run Before Write" but with no luck. Any hints, please?
EDIT: In another workspace with another schemas but with similar tasks it runs without errors as expected. The triggers with its functions are almost identical.
Best answer by albinepro
So it was quite foolish mistake creating Postgres extension in other schema than "public". Recreating it in "public" worked.
albinepro
  • Mar 30, 2023 9:16 AM UTC
