Revit to IFC conversion Error
  • Mar 15, 2018 9:20 PM UTC
  • 5 replies
  • 68 views
Hi!
I received an IFC file from a costumer and when I tried to inspect the file in Data Inspector, I received the attached error message.
I don't know much about Revit so I'm at a lost. Any help to what this means, would be greatly appreciated!
Thanks,
David
I should note, I can open other IFC files, but not the ones provided.
  • Mar 16, 2018 9:57 AM UTC
The error message gives the impression of an unexpected token.
Maybe try the lastest FME 2018 to see if it makes a difference?
https://www.safe.com/support/support-resources/fme-downloads/
If not, consider sending the ifc file to Safe support, together with your workspace and log file.
Thanks @david_r for the response! I only tried open the IFC file in data inspector, to see what was in it. I cannot send the IFC file, due to policy. But, how can I inspect other IFC files, but this one causes errors? Could this be a Revit to IFC conversion error?
Thank you,
David
I attached the log file, that writes when I try to inspect the file.
lars_de_vries
Forum|alt.badge.img+10
I have received this error multiple times in FME. Mostly it is an error in the IFC-file. When you open it in an application like Notepad++ (it will probably load a long time), the file should end with:
ENDSEC;
END-ISO-10303-21;
If the IFC-file does not end that way, FME won't read it, since the file did not end properly. The only thing you can do, is trying to create a new export from Revit.
