Is there any workaround to export 3d pipes from revit to postgis 3d? I installed the fme plugin to revit and exported into ifc with various options on but none of the exported files contained (or at least I couldnt find). My and goal is to export 3d pipes with various attributes + the 3d geom into postresql/postgis and visualize it in augmented reality (augment . net) Could you provide me some help how can I export pipes from revit to postgis 3d?
Revit pipes network to 3d GIS (Postgis)
