Revit file (.rvt) Projection System
  • Sep 9, 2019 7:15 AM UTC
  • 63 views
vini.devgan
Hi, I have .rvt file which is created with DUB DLTM projection system, I do not see the feature on the correct location in FME inspector, or in ArcMap after transforming the file into multipatch file geodatabase.
I can see the feature on correct location when adds the file directly into ArcGIS Pro but facing issue with FME.
I am using FME 2019.1, which allows direct reading of .rvt file, no need to convert .rvz or ifc
Looking for a solution.
sigtill
Forum|alt.badge.img+25
  • Sep 10, 2019 7:58 AM UTC
Try to add a Coordinatesystemsetter and then redirect to Inspector
