Retrieve value from CSV Column Header
  • Mar 18, 2020 10:21 AM UTC
  • 187 views
nedwaterman
Forum|alt.badge.img+9
Hello,
I need to retrieve the value of a column header in a CSV file. The column header contains the ID of a meter I need to use as an insert into a database. Unfortunately I can't use a filepathreader as the id filed isn't included.
Any idea how I might do this? I have attached a test file. The value I need to extract from the column header is the string after the undescore.
Best answer by ebygomm
If you read the csv without a field names line so your attributes are returned as col0 and col1, the first record will contain the value in col1 and you can use a string searcher with some regex to return the value.
Forum|alt.badge.img+54
  • Mar 18, 2020 10:25 AM UTC
nedwaterman
  • Mar 18, 2020 10:43 AM UTC
Brilliant - thank you!
