Retrieve data from Microsoft fabric lakehouse.
  • March 17, 2024
  • 907 views
fme_hans
Forum|alt.badge.img+5
Hi
Is it possible to connect fme to a Microsoft Fabric Lakehouse? And read data?
I use fme 2022.2
hkingsbury
Forum|alt.badge.img+67
  • March 17, 2024
Have a look through the REST API documentation - https://learn.microsoft.com/en-us/fabric/data-engineering/lakehouse-api
Using this with an HTTPCaller should get you started
rajeeban_a
  • November 27, 2025
There’s a new  Delta Lake Reader available in FME 2025.2, which can read Microsoft Fabric Lakehouse tables directly. However, since you’re on FME 2022.2, you may need to use the REST API with an HTTPCaller instead to access the data as ​@hkingsbury mentioned above.
