Results from Oracle stored procedure
  • Apr 1, 2014 11:00 PM UTC
  • 292 views
chrisr
Is there a way that I can get hold of and use the results from calling a stored procedure in a SQL Executor?
My procedure seems to run fine, but I haven't been able to get anything out of the Result output port of the SQLExecutor.  The stored proc queries a mapping table and returns either an existing id or a newly-created one (or an error).
My SQL looks something like this:
declare
  ID number;
  STATUS number;
  ERRMSG varchar2(128);
begin
  schema.get_new_id(@Value(obj_id),'@Value(table_name)',ID,STATUS,ERRMSG);
end;
Again, it seems to run fine, but I would like to use the output variables ID and STATUS on the feature farther along in the workflow (e.g. to set an attribute value).
Any assistance is appreciated.
Thanks!
  • Apr 2, 2014 7:26 AM UTC
does schema.get_new_id() have any return values? This is necessary. You cannot have return values in the anonymous block in your SQLExecutor (not supported by Oracle), so the function get_new_id() must RETURN the values ID and STATUS to you. Declaring the results as OUT isn't enough here, they must be explicitely returned, i.e. get_new_id() must be a function, not a procedure.
If you can modify the declaration of get_new_id() to RETURN the results, or eventually create a PL/SQL wrapper function around it to do it, you can then do something like this in your SQLExecutor:
select ID, STATUS, ERRMSG
from table(schema.get_new_id(@Value(obj_id),'@Value(table_name)'))
You can then expose the resulting ID, STATUS and ERRMSG as feature attributes in the SQLExecutor, as usual.
See also the example here http://stackoverflow.com/a/9484311/370301
David
See also the example here (http://stackoverflow.com/a/9484311/370301).
David
chrisr
  • Apr 2, 2014 3:30 PM UTC
David - thanks for your response!  I don't have it solved yet, but this is helpful.
