Reserved words for variable values?
  • Sep 22, 2017 8:04 AM UTC
  • 95 views
oscard
Forum|alt.badge.img+23
Good morning!
Today my FME Desktop 2017.0 has given me the following error while running a Workspace:
It doesn't start at all. Not even the log is written.
This is a workflow to update several metadata XML files. For the ID of those metadata I have used "fme_(type_of_metadata)". For the ATOM service and the Dataset metadata is working fine, but with the view service metadata always gives me the error from the pic.
If I change the metadata ID to something else, the workspace runs without issue. So it seems I have hit some restricted words for the "metadat_id" variable value.
Is there any place in the documentation where I could check which words we are forbidden to use?
Thanks!
Best answer by david_r
I don't think there are any reserved words used in your screenshot above (I'm not sure if there any reserved words other than those reserved by the OS).
To test, I created an empty workspace in FME 2017 and defined the exact same published parameters:
It runs perfectly, so I suspect something else is the problem.
  • Sep 22, 2017 8:18 AM UTC
oscard
  • Sep 22, 2017 8:32 AM UTC
I thought it was weird, too. But the only thing I have changed to make it work is the "metadata_id" when I'm processing the view service XML file.
At first, I thought it could be that the view service XML file wasn't OK. So, I have taken one of the other XML files that are working fine and treated it as the view service metadata. Same error.
As I have said, not even the log is wirtten; so the error is not in the workflow. My next idea was checking for blank spaces in the "metadata_id" value, but there wasn't any (although it should be able to accept them).
So changing the ID has been the next step. From "fme_cp_viewservice" to "cp_viewservice_fme"... same error. From "cp_viewservice_fme" to "test": It works!. From "test" to "fme_cp_viewservice" (just in case)... the error again. From "fme_cp_viewservice" to "geo_viewservice": It works again!
Maybe it's random and my FME is having a bad day today...
  • Sep 22, 2017 8:36 AM UTC
That's really weird. I'd consider sending the workspace to Safe support for analysis.
