Repair Geometry with ArcGIS Repair Geometry tool
  • Jan 16, 2025 4:43 PM UTC
  • 322 views
matt.albritton
Forum|alt.badge.img+17
How can I use the Python caller transformer to call Arcpy and run the ArcGIS Repair Geometry tool? I have polygons from a file geodatabase that I'm importing into our Postgres SDE. After loading them, many of the records won't display due to geometry violations. I tried using the FME Geometry Validator transformer in my workspace, but it didn't seem to resolve the issue.
Alternatively, is there a way to configure the Geometry Validator (or combine it with other transformers) to repair the data?
becchr
Forum|alt.badge.img+35
  • Jan 16, 2025 4:58 PM UTC
this might get you started for using arcpy?
https://support.safe.com/hc/en-us/articles/25407493532429-Using-Arcpy-for-FME-Feature-Processing
for repairing geometries in FME, many possibilities, but we should get more info I guess, any sample data/workspace you could share, or more details on the errors/violations you are talking about?
hkingsbury
Forum|alt.badge.img+73
  • Jan 17, 2025 1:18 AM UTC
As ​@becchr suggested, you can do geometry repairs in FME. Have a look at the GeometryValidator and its ability to repair geometry - https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/geometryvalidator.htm
danilo_fme
Forum|alt.badge.img+58
  • Jan 17, 2025 2:55 PM UTC
Great.
