Remove outlier contour lines
pauld
Hi. I have created contour lines from DEM rasters and I’m getting outliers (straight lines to random points).
What is the best way for me to remove these lines?
Best answer by redgeographics
Looks like islands, if you have a coastline polygon you can use that to clip the contours for a quick and dirty solution
Forum|alt.badge.img+49
  • June 24, 2024
pauld
  • June 26, 2024
Thanks @redgeographics for the solution. It resolved my issue effectively. 😊
 Regards, Paul
