Remove excel column
checcosisani
Forum|alt.badge.img+12
Hy
I need to read several excel files and remove a lot of columns (fields) so the usage of attribute manager isn't efficient
How can do this in smart way ?
thx
Francesco
Forum|alt.badge.img+50
If you need to remove lots of columns try the AttributeKeeper, there you can select which ones you want to keep (if you want to keep more than you want to remove, there's the AttributeRemover which works the other way around).
checcosisani
  • February 8, 2019
Hi
yes I realize that attrkeeper can helps me but any idea how can automatize the selection in attribute keeper (I have 1850 columns and I have to keep 30)?
thx
Francesco
Forum|alt.badge.img+39
  • February 8, 2019
Is there any sort of common naming for the attributes you want to remove? If there is the BulkAttributeRemover might be useful here
checcosisani wrote:
Hi
thx
Francesco
Perhaps the SchemaMapper can be used, I haven't worked with it myself in a long time, but there's a tutorial here.
Alternatively, Python might come in handy, but again, no experience with that myself.
