Remove empty fields
  • Jan 9, 2017 7:06 PM UTC
  • 10 replies
  • 731 views
arthy
Forum|alt.badge.img+8
Is there a way to extract only the non-empty fields of an oracle table?
Let's say I have a table like this one,
    col_a    col_b    col_c    col_d   col_e
    NULL     NULL     NULL     NULL    5
    NULL     NULL     NULL     8       6
    0        NULL     NULL     NULL    3
    NULL     NULL     NULL     0       1
and the subtable that I would like to extract should be
    col_a    col_d   col_e
    NULL     NULL    5
    NULL     8       6
    0        NULL    3
    NULL     0       1
Thanks
Best answer by xiaomengatsafe
Another option is to use the AttributeExploder to turn each attribute name and value pair into individual features, then filter out only ones where value is not empty. And create a schema feature using the filtered result. In a Dynamic Writer, Schema definition can come from Schema features. This will ensure writer don't write out columns without any value.
I attached a sample workspace for reference. the source shapefile has one column "COUSUBNS" where all values are empty, on the output, that column is not written.
Hope this helps.
Also for more details on working with AttributeExploder result, you can reference the beginning part of this tutorial: https://knowledge.safe.com/articles/31701/transpose-a-table-using-fme.html
And on Dynamic writing where schema is defined by Schema Feature, you can read more here: https://knowledge.safe.com/articles/1051/index.html
remove-columns-with-only-empty-data.fmwt
erik_jan
Forum|alt.badge.img+26
  • Jan 9, 2017 7:11 PM UTC
After reading the data the NullAttributeMapper transformer (If Null set to Missing) can remove all Null attributes.
itay
Forum|alt.badge.img+19
  • Jan 9, 2017 7:19 PM UTC
Have you tried a SQL statement on the database to read non-null columns?
select column_name
from user_tab_columns
where table_name='Table_name' and num_nulls=0;
arthy
  • Jan 9, 2017 7:22 PM UTC
@erik_jan, In the example above, the input table has 5 columns while the output table has 3 columns.
The NullAttributeMapper won't give this result.
erik_jan
  • Jan 9, 2017 8:03 PM UTC
I see what you mean:
In that case I can only think of using the StatisticsCalculator (max value) and a Tester (If max value > 0). On Failed an AttributeRemover.
Not really straight forward but this could work.
xiaomengatsafe
Forum|alt.badge.img+11
Hope this helps.
jdh
Forum|alt.badge.img+41
  • Jan 31, 2017 10:20 PM UTC
Hope this helps.
I've done the equivalent to this using python to filter the attributes and create the schema feature.
trevorm
Forum|alt.badge.img+3
  • Aug 17, 2022 5:53 PM UTC
Hope this helps.
Hello I'm trying to use the Remove-columns-with-empty-data work space and Cosbuns appears to still show up in my FeatureMerger (End). The solution on my data works perfect on the top pathway and removes all my "all null columns" , but the merger appears to be bringing them all back in.
JennaKAtSafe
Forum|alt.badge.img+9
Hi @trevorm​ , would you be able to provide screenshots or a sample of your workspace? I would also suggest starting a new thread with your question as this thread is fairly outdated
trevorm
  • Aug 22, 2022 3:17 PM UTC
I can start a new thread, but how do I reference this threat as I'm trying to reproduce remove-columns-with-only-empty-data.fmwt
If the content on the forums are out of date or no longer working with the current version is there a way to remove them from my search results? I want to remove columns from my .csv that have all "null" values.
I have taken this work space and ran it <except the writer>
I'll start a new workspace with your help, as this is a great way to ensure my .csv gets cleaned without missing some data at the bottom.
evieatsafe
Forum|alt.badge.img+28
  • Aug 23, 2022 11:42 PM UTC
Hi @trevorm​ to answer one of your questions: we are looking to improve the search function on the community to view the relevant version that applies to you; however, we are not quite there yet. Keep a look out for that in the future!
You can also start a new question with links to the resources that are relevant such as this question, articles, and even attach data and workspaces.
To answer your question about your column removal workspace question, and I believe that that workspace should work. Unless you have an issue that you could provide an example workspace for, I'm not sure I can fully answer your question. Look forward to a response!
