Remove Comments from XML file (:
  • Dec 3, 2014 5:28 AM UTC
  • 11 replies
  • 125 views
parashari
I am working on Win7 Machine with 8Gb RAM.
While creating an XML from a shapefile, comments are being generated automatically which I want to remove. Tried XMLFormatter and StringReplacer, but didn't get the desired output. Can someone help me with that (:
(The rows inside the box are automaticallygenerated and should be removed)
  • Dec 3, 2014 9:14 AM UTC
I think the StringRepalcer can do that.
Text to Match: <[\\?/]?(xml|fme:)[^<]+>\\n?
Replacement Text: <blank>
Use Regular Expressions: yes
... but those lines are parts of the XML document, not comments. The resultant text may not be a valid XML document no longer.
Why do you need to remove them?
Takashi
parashari
  • Dec 3, 2014 9:46 AM UTC
Hi Takashi,
I tried using StringReplacer. But since, those comments are not a part of any XML Schema, those cannot be found using StringReplacer.
I need to remove those comments as I have to convert those XMLs to some other internal format. Cna't there be any other option ):
  • Dec 3, 2014 10:51 AM UTC
I supposed that the XML document has been read by the Text File reader. Was my supposition wrong?
  • Dec 3, 2014 10:52 AM UTC
how about reading the XML file using the Text File reader, followed by a StringReplacer:
Text to Match: (?s)<!--.*?-->
Then write it out with the Text File writer again.
There are also a few command line tools that can do it for you, have a look here for more options: http://stackoverflow.com/questions/1464697/stripout-comments-from-xml
David
parashari
  • Dec 3, 2014 11:09 AM UTC
@Takashi: No, I am not using Text file Reader.
@David: I tried using XML Textfile Reader, nothing was shown in o/p.
I think something can be done in o/p parameters using Navigator bar.
  • Dec 3, 2014 11:22 AM UTC
As David suggested, it seems that Text File reader -> StringReplacer -> Text File writer is quick way. Is there a reason that the Text File reader/writer cannot be used?
parashari
  • Dec 3, 2014 11:54 AM UTC
I am not sure about how to do it.
Do I need to run two WBs for that. One for Shp to txt and other for txtto xml?
How Exactly to go about it?
  • Dec 3, 2014 12:10 PM UTC
XML is a kind of text. You can read/write simply an XML document with the Text File reader/writer.
Since you've already created the xml file with a workspace (shp to xml), you don't need to touch it.
Create another workspace (xml to xml):
- read the xml file with the Text File reader,
- remove unnecessary parts with the StringReplacer,
- write the resulting text with the Text File writer.
  • Dec 3, 2014 12:29 PM UTC
Just be aware that you may have to set encoding of the Text File writer to the same one that is declared in the first line of the XML.
<?xml version="1.0" encoding="UTF-8"?>
oops, you are going to remove it (screenshot). If you removed it, the text is not an XML document no longer.
You really need to remove it?
parashari
  • Dec 5, 2014 6:05 AM UTC
Hah !!! :P  Thank you all.
I tried running two WBs
1) shp to txt
2) txt to xml
And it is working perfectly. Using StringReplacer, it is doing exactly the way I wanted. The only issue left now is there are empty lines coming in place  of comments.
parashari
  • Dec 9, 2014 4:42 AM UTC
Thank you all for your ideas :)
I tried using Tester with operator 'Attribute Is Empty' and it worked (with correct parcing).
StringSearcher can also be used with ^$ to find empty rows.
http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000csytAAA
