Regex preview highlight bug
  • Jul 24, 2024 8:48 AM UTC
  • 78 views
jkr_wrk
Forum|alt.badge.img+37
The preview highlights the letters Op but the Regex only replaces the quotes (as expected):
Result:
‘Op. test ’ will become _Op. test _
liamfez
Forum|alt.badge.img+44
  • Jul 24, 2024 11:50 AM UTC
Well that is interesting. I am not seeing that extra highlighting with 2021.1 and 2022.1 when I test your string. I tried double and single quotes in the string and in the regex.
I am not the best with regex but do you need 2 single quotes?
itsmatt
Forum|alt.badge.img+48
  • Jul 24, 2024 1:22 PM UTC
I did some experimenting and what able to reproduce it but it was a bit weird and seems to be a result of copy and paste.
If I hand type the test string and regex I get a good result, If I copy and paste the text from your question about I get 0 matches. If I copy use the quote mark from the text string I gut the same result as you.
Typed
From the text in your question
Copied quotes into regex
Somehow I’m guessing there is a difference in the encoding here. Maybe UTF-16 vs UTF-8
