Reading & Writing to MySQL
  • May 20, 2014 1:23 PM UTC
  • 85 views
dilip
Forum|alt.badge.img+5
I am reading data for MySQL and would like to prevent migrating the same data each time i run the workbence (it will be running as a scheduled task). To do this I have created an 'export' field in MySQL, with a default value of '0'. The workbench has a tester at the start, that will only allow a value of '0' through, and at the end of the workflow, I want to change all '0' values to '1'. I get an error when trying to run this writing back to the MySQL database.
My question is this, normally I would use the database updater transformer, but this will not write to MySQL, so how would I update the MySQL database and change these values.
Many thanks in advance.
Best answer by david_r
What kind of error are you getting from MySQL?
Also, have you tried using an SQLExecutor?
David
  • May 20, 2014 1:55 PM UTC
David
dilip
  • May 20, 2014 3:17 PM UTC
Thanks David, I was trying to use the standard writer wich failed, the SQLExecutor worked a treat.
Many thanks
