Reading/Writing Microstation Properties
  • Apr 6, 2017 9:43 AM UTC
  • 6 replies
  • 100 views
Hello,
I am trying to read or write the various text attributes such as "Title" or "Comments" listed in Microstation under File -> Properties. I have checked all format attributes in my DGN Reader as well as trying different reader parameters to get the attribute to show up in my inspector - no luck so far.
Is there some way to read these as FME attributes?
Thanks in Advance
itay
Forum|alt.badge.img+19
  • Apr 6, 2017 10:21 AM UTC
Also exposing all the text attributes doenst help?
Are these actual features (points, lines etc)?
Thank you for your reply.
Yes, I have selected all of them and searched for the value I typed in via Microstation - no dice.
My DGN file contains point/line/polygon geometries.
itay
  • Apr 6, 2017 1:09 PM UTC
Which reader version are you using? V7 or V8?
I'm using the "Bentley MicroStation Design (V8)" reader.
Hi @philipp_voelker
unfortunately, these dgn-file properties are not supported by FME at the moment. Could you please suggest this functionality as a new idea (please see NEW IDEA in the top right corner of this page). If this functionality is urgent and/or critical for your project, please submit a support case through https://www.safe.com/support/
Hi @philipp_voelker
Thank you for the heads-up. I will suggest this as a new idea.
