Reading unversioned SDE table with archiving enabled
  • Dec 4, 2015 9:34 AM UTC
  • 5 replies
  • 107 views
Forum|alt.badge.img+3
I'm trying to connect to an unversioned table that has archiving enabled. I'm using the Esri Geodatabase (ArcSDE Geodb) reader. I connect as the owner of the table, the same user that was used to enable archiving.
In the table list i cannot see the table ending in _evw (the database view containing the archived information), only the feature class itself. Should I be able to see the _evw-table?
I add this Archive Where clause: GDB_FROM_DATE > 20070101090000
When trying to read the features, I get this error message: "Invalid archive where clause. The archive where clause must be in the format 'GDB_FROM_DATE|GDB_TO_DATE <logical operator> <date> [AND GDB_TO_DATE <logical operator> <date>]' and be space delimited."
What am I doing wrong? Are there any other fields I should have filled in? Could the date format be wrong? There are no historical versions or historical markers in the database.
  • Dec 4, 2015 10:22 AM UTC
Concerning the view, it will depend on your ArcGIS version and how the view was defined. In general, if it is a regular database view you will have to either register it as a layer in SDE to make it visible in ArcGIS (prior to ArcGIS 10.2 I believe), or you will have to define it as a query layer (starting with ArcGIS 10).
David
  • May 2, 2016 11:40 AM UTC
I think you have forgotten doubles quotes. The following archived clause should work :
"GDB_FROM_DATE > 20070101090000"
Nicolas
  • Nov 7, 2016 8:48 AM UTC
Hi all,
I want to reopen this topic as I encountered an unexpected behaviour in FME 2016. When I use an ArcSDE-Reader and insert e. g. "GDB_FROM_DATE > 20070101090000" (with double quotes) for Archive Where Clause, I get the desired results.
When I use a FeatureReader and input the same feature class and Archive Where Clause, however, I get the following error message:
Does the FeatureReader-Archive Where Clause parameter expect another format and outputs the wrong error message? I have also checked this thread but couldn’t find anything relating to FeatureReader specific adpations.
Best regards,
André
PS: I am using FME 2016.1 (Build 16494).
fmelizard
Forum|alt.badge.img+22
  • Nov 9, 2016 11:19 AM UTC
Hi Folks,
We are looking a new variation of this problem mentioned by @andr_ where the Archive Where Clause is not working when used in the FeatureReader and indeed this is a known issue. In fact the problem is related to original issue posted by @ turid_skedsmo where we noticed you need to use double quotes around the Archive Where Clause. Unfortunately this work-around doesn't work in the FeatureReader. We are looking for a work-around and our developers are looking into this problem but in the meantime apologies for the inconvenience.
Ken
  • Nov 9, 2016 12:54 PM UTC
@KenAtSafe : Thanks for the fast response. Do you have, by chance, any information on when this issue may be fixed?
