Reading multiple shp files from sub folders
  • Jul 2, 2019 12:29 PM UTC
  • 256 views
Hello,
I have one folder with multiple sub folders that contains multiple shp.
I need to read in all shp with specific name from all sub folders.
Is this possible in FME?
Structure is something like this:
Folder
-SUB Folder1
-1.shp
-2.shp
-SUB Folder 2
-1.shp
-2.shp
Example, I need to read all 1.shp together.
Best answer by ebygomm
Assuming the shape files have the same structure, you can use wildcards in the source parameter to read every shp file in a folder named 1.shp
e.g. D:\\Folder\\**\\1.shp
Forum|alt.badge.img+54
  • Jul 2, 2019 1:25 PM UTC
  • Jul 3, 2019 6:58 AM UTC
Thank you.
