Reading CSV files with different schemas and writing to SQL server.
  • Apr 2, 2025 9:21 PM UTC
  • 187 views
ifawzi
Participant
I am new to FME, and I am trying to build an FME workspace that reads multiple .csv files from a folder and write each file to separate table in SQL server. Each CSV file:
  • has different schema
  • should became it is own SQL table
Here is what I tried so far:
  1. I used Directory and File Pathnames reader
  2. I used Feature Reader
The <Generic> port of Feature Reader shows no data, I am assuming because the schema of each is different. the <initiator> port give me the correct file name and path.
j.botterill
Forum|alt.badge.img+69
  • Apr 3, 2025 12:45 AM UTC
You will want to connect both the Schema port and the Generic or FeatureType data output ports of a feature reader, going into a FeatureWriter.
Read up about Dynamic Writing
On the FeatureWriter, you need to set it to fme_feature_type and the schema
crutledge
Forum|alt.badge.img+55
  • Apr 3, 2025 1:37 AM UTC
