Reading Blobs from Oracle
  • October 21, 2019
  • 4 replies
  • 104 views
oliver.morris
Forum|alt.badge.img+12
Is there a way to read an oracle blob file within FME. I know the structure and can read with python, is it possible to do something with FME? Is it possible at least to read in the blob with FME then use a python caller to extract using the struct library?
Many Thanks as always,
Oliver
cursor.execute("SELECT BLOB_DATA,DATATYPE,BYTES_USED,BLK_NO FROM {}.GEO_SHAPE WHERE VID={}".format(xxx,19971))
ORACLErow = cursor.fetchall()
for row in ORACLErow:
    print row
    print struct.unpack('>d',row[0].read(1,8))[0]
    print struct.unpack('>d',row[0].read(9,8))[0]
    print struct.unpack('>d',row[0].read(17,8))[0]
    print struct.unpack('25s',row[0].read(25,25))[0]
    print struct.unpack('>i',row[0].read(50,4))[0]
Best answer by daveatsafe
Hi @olivermorris,
FME will read the Oracle blob fields as binary attributes on the row feature. You can then use a PythonCaller to interpret them. Use FMEFeature.getAttribute() to read the attribute in Python.
daveatsafe
Forum|alt.badge.img+19
  • October 21, 2019
Hi @olivermorris,
oliver.morris
  • October 22, 2019
daveatsafe wrote:
Hi @olivermorris,
Thank you, I have tried this and get an issue with my python:
import fme
import fmeobjects
import struct
def geo1(feature):
    myrow = feature.getAttribute('BLOB_DATA')
    ##xcoord = str(myrow)
    xcoord = struct.unpack('>d',myrow.read(1,8))[0]
    feature.setAttribute("xcoord",xcoord)
I get the error
2019-10-22 16:38:34|   0.5|  0.2|ERROR |Python Exception <AttributeError>: 'bytes' object has no attribute 'read'
yet this does work in python idle. Any ideas?
Thank you
oliver.morris
  • October 22, 2019
import fme
import fmeobjects
import struct
def geo1(feature):
I get the error
Thank you
I now get: byte indices must be integers or slices, not tuple
daveatsafe
  • October 22, 2019
Hi @olivermorris,
According to the FMEObjects Python docs:
Binary blob attributes are returned as a bytearray in Python 2.7 or bytes in Python 3.
I think this is OK for struct in 3, but 2.7 you may need to use the workaround discussed in https://codereview.stackexchange.com/questions/37959/struct-unpack-on-a-bytearray-that-works-under-python-2-6-6-2-7-and-3-3.
