Reading a FieldSmart Redline XML File.
  • Oct 8, 2019 4:17 PM UTC
  • 59 views
I am trying to get the file name along with a coordinate from our FieldSmart redline note XML files. They are not a traditional XML document. I am able to get 12 rows from the attached XML file but I want the 12 rows to be 12 attributes. How can I do this?
debbiatsafe
Forum|alt.badge.img+24
Hi @donjensen
As mentioned in this Q&A post, it is possible to use attribute values to create new attribute names using an AttributeCreator, although you will have to expose the newly created attributes using an AttributeExposer.
Perhaps you can try this method and then use an Aggregator with Accumulation Mode set to 'Merge Incoming Attributes' to create a single feature.
  • Oct 9, 2019 3:50 PM UTC
Thanks for the suggestion. I ended up using an aggregator as us suggested and then an Attribute Manager to split the attributes out from the list.
