I'm using the Data Interoperability extension and I'm attempting to read in a csv file that has a column with a string of coordinates in it. I've tried loading it into the Spatial ETL Tool CSV reader, using the coordinate concatenator and then the area builder. I get a rejected feature warning when I try running the tool. Can anyone offer some pointers for this?
Reading a CSV file with multiple coordinates in one attribute
Best answer by erik_jan
Use a AttributeCreator to concatenate the coordinate string into this format:
POLYGON ((0 0,10 0,10 10,0 10,0 0))
Then use the GeometryReplacer (OGC Well Known Text) to read the attribute as geometry.
Hope this helps.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
