Reader character encoding problems in oracle layers with where parameters
  • May 4, 2020 7:12 AM UTC
  • 6 replies
  • 173 views
Hello,
I am trying to read and oracle layer with -where- condition but i have problem because it failed with reading of character Ë or Ç.
I get this error:
ORA-01756: quoted string not properly terminated'
If i replace Ë with E, it is ok.Find below part of the error log.
  • May 4, 2020 7:26 AM UTC
Did you try prefixing the string literal with N as I suggested? Example
where my_field = N'KËLCYRË'
Or did that not work?
No, it didn't work but i noticed that this happen if the field is a published parameter, because if i fill it directly in the where script it is ok, but if i use it as a parameter (my_field='($P1)') i get the same error.
  • May 4, 2020 12:25 PM UTC
It's most probably a problem with character encoding. My recommendation would be to use the ParameterFetcher first, then play around with the AttributeEncoder before the SQLExecutor. Possible encodings include UTF-8, the different ISO-Latin (iso-8859-x) character sets and perhaps also the Windows code pages.
It will depend on the Oracle client code page settings, column datatype, your locale settings, etc.
mark2atsafe
Forum|alt.badge.img+59
According to the information I can find, FME does allow international/unicode characters in WHERE clauses. So it should work.
I see an issue filed where a transcoding problem can occur if the char and nchar encodings are different (I see yours are from StackExchange). But I don't know if that would cause this error or not.
The fact that it fails with an unbalanced query (no closing quote) worries me that this is something new. I suggest that you visit safe.com/support and file a new support case. You should mention that it could be related to FMEENGINE-10146 - and then someone will be able to try and resolve the issue.
It would help a lot of if can include full specifications for the data (column type, Oracle version, etc) plus the workspace you are using.
rahulsharma
Forum|alt.badge.img+12
Can you try including the single quotes in the publish parameter value?
WHERE my_field=N$(P1)
P1='KËLCYRË'
No,didnt work even with that.
