Read "Tabular JSON" with Schema Separate from Values
  • Feb 3, 2026 9:49 PM UTC
  • 84 views
paul_m
Forum|alt.badge.img+26
Does anyone know a good built-in or pre-created solution to read “Tabular JSON” that’s in a format of schema followed by values rather than key:value? See example below. I have ~40 schema values but only included 2. I’m looking for something dynamic rather than manually assigning column names in a specific order.
"schema": {
"title": "Data Export",
"type": "array",
"properties": {
"id": {
"title": "id",
"type": "integer",
"default": "",
"minimum": -2147483648.0,
"maximum": 2147483647.0
"code": {
"title": "code",
"type": "string",
"default": ""
"data": [
1,
"DEMO1234"
paul_m
  • Feb 3, 2026 10:36 PM UTC
Using the PythonCaller and AI Assist with a few small adjustments and an AttributeExposer (use import from data cache after running the PythonCaller), I was able to get this working for the most part. Here’s the code I used in the PythonCaller:
import fme
from fme import BaseTransformer
import fmeobjects
import json
class FeatureProcessor(BaseTransformer):
def __init__(self):
self.schema = None
self.data = None
def input(self, feature: fmeobjects.FMEFeature):
# Parse the JSON response from the _response_body attribute
json_response = feature.getAttribute("_response_body")
parsed_json = json.loads(json_response)
# Extract schema and data
self.schema = parsed_json.get("schema", {}).get("properties", {})
self.data = parsed_json.get("data", [])
# Process each row in the data array
for row in self.data:
new_feature = fmeobjects.FMEFeature()
for index, (key, value) in enumerate(self.schema.items()):
column_name = value.get("title", key) # Use the title from schema or fallback to key
new_feature.setAttribute(column_name, row[index])
# Output the new feature
self.pyoutput(new_feature)
def close(self):
pass
daveatsafe
Forum|alt.badge.img+24
  • Feb 4, 2026 4:43 PM UTC
Hi ​@paul_m,
The attached workspace should assign the attribute values correctly from your source JSON, using only transformers. This looks a bit more complex than the Python, but may be more understandable to FME users.
