Read Share Group information from Esri Enterpise
  • Jan 29, 2025 12:42 PM UTC
  • 5 replies
  • 88 views
marta.podsiad
Forum|alt.badge.img+12
I am having trouble reading the names of the groups with which the layer is shared in Esri Enterprise.
I am using an HTTPCaller with the following settings, but the Share info does not appear in the JSON response.
The only information I get is:   "access": "shared".
Could you please advise on how to retrieve this information?
Best answer by marta.podsiad
I have found the solution
https://your-portal-url/sharing/rest/community/groups/{groupID}?f=json
nielsgerrits
Forum|alt.badge.img+67
You will need another route for this info:
https://<portalUrl>/portal/sharing/rest/content/users/<userName>/folderId/items/<itemId>
You can find this by logging in to the Community Root:
https://<portalUrl>/portal/sharing/rest/community
The follow Self, User Content, select folder, select item and look for Sharing Groups on the bottom of the page.
marta.podsiad
Thank you for the reply but I think I am doing sth wrong. My link looks something like that
and it does not work. I got and error
<b>Error: </b>400<br/><br/>
nielsgerrits
I think you forgot to replace the folderId.
You can use the browser to access
and go from there.
marta.podsiad
I have used this request
https://maps-eu.xxx.com//portal/sharing/rest/content/users/MPOD@xxx.com/items/@Value(itemId)/sharing?f=pjson
and got this info:
  "sharing": {
    "access": "shared",
    "groups": [
      "035d3b1262bb4dddfdfd9a0a260e2c4d76e4",
      "ce750fea888a4ddfdfdfddfde6065536adfa31"
How can I find the actual name of the group?
marta.podsiad
  • Feb 3, 2025 6:47 AM UTC
