Read only the 1st line of Text/CSV File
mmccart
Forum|alt.badge.img+17
I have a CSV file where I need to read only the first line (or first column/line combo) of the file. Is there an easy way to do this with a reader? Or am I stuck reading the whole file? I've tried both the CSV reader and Text File reader. In both, I don't see anyway of isolating this first line of text/data. I'm forced to bring the entire table into the workspace.
Thanks in advance!
-Mark
Best answer by ebygomm
You should be able to set the max features to read to 1 in the csv reader parameters in the navigator
Forum|alt.badge.img+34
  • March 3, 2020
mmccart
  • March 3, 2020
Thanks @ebygomm. I actually need to use a FeatureReader, but just saw the 'Max Features To Read' option. I don't know how I missed it.
Setting this to '1' worked perfectly!
