read nested block autocad
  • Jun 13, 2019 1:59 PM UTC
  • 0 replies
  • 85 views
alc33
Forum|alt.badge.img+14
Hello!
I have nested blocks on autocad because I need to have the same block with the insert location on a other place. So, on autocad, when you explode the block1 you obtain the block2. I cannot change this configuration because is used for a long time. The 2 blocks have the same name.
Is it possible to extract the block nested (block2) without explode it? Or at least extract the insert location of the block 2? When I explode the block on FME reader parameters, FME explode all the elements and keep only the insert location of the block1. There is no option of "hierarchical" explosion.
Thank you!
