Read Map Image Layer from Esri Portal
  • Jun 30, 2025 11:18 AM UTC
  • 6 replies
  • 221 views
marta.podsiad
Forum|alt.badge.img+12
I would like to save a copy of Map Image Layer from Esri Portal into gdb. Esri ArcGIS Portal Feature Service does not recognise raster layers and ArcGISOnlineConnector does not recognise geomety. What is the way around?
crutledge
Forum|alt.badge.img+55
  • Jun 30, 2025 11:28 AM UTC
Hi ​@marta.podsiad I have run into this on our Enterprise Portal. I plan to publish as wms to test whether I can use the wide range of ogc tools available. Is that an option on your side? To publish an additional wms beside your esri MIL?
nielsgerrits
Forum|alt.badge.img+67
Is the source vector or raster? If vector, the Esri ArcGIS Server Feature Service works best for me to retrieve geometry.
crutledge
  • Jun 30, 2025 11:51 AM UTC
Good point ​@nielsgerrits
​@marta.podsiad Since a Map Image Layers (MIL) is a collection of Raster Images of your data rendered and served at a set of map scales I haven’t been able to use the portal/agol readers for MIL. Is the data you are trying to use a MIL or a Hosted Feature Layer (or even a tiled imagery/vector service?). Different services require different tools.
marta.podsiad
The MIL is a raster
Published via ArcGIS Pro
nielsgerrits
nielsgerrits
It is simply possible to retrieve the geometry from a map image layer using the Esri ArcGIS Server Feature Service reader, you do not need a featurelayer for that, hosted or not.
But as I understand, you published a tif as map image layer, and now you want to export a tif from it?
What I once did what use the rest api export functionality to request exports from a bigger extent, georeference those and mosaic that together. It was quite a bit of work and I was not too pleased with the result. So I would not advise that.
If I need this now, I use Global Mapper to simply export an extent of an earial service to an ECW, but it still takes a lot of time.
