Read Excel File with sheet names, row and column numbers?
  • Dec 7, 2017 5:03 PM UTC
  • 208 views
I have a large number (~1000) Excel files that I need to import into a database table. They are many different formats, so using a reader with a defined schema will not work. I would like to have the output contain the following attributes:
  • Filename
  • Sheetname
  • RowNumber
  • ColumnNumber (preferably as a number but could be letters as used in excel)
  • value (as text)
I've tried numerous things and searched through many posts. It seems like this should be a simple task, but the Excel Reader attempts to detect a "schema" for a sheet, and it uses values it finds wherever in the excel as attribute names. Any suggestions would be greatly appreciated.
jdh
Forum|alt.badge.img+41
  • Dec 7, 2017 6:08 PM UTC
What about using the Schema Reader to read in the excel files, that will give you attribute{}.name, with the index being the Column Number, the Filename would be fme_dataset (or fme_basename if you don't want the full path), the sheet name fme_feature_type_name.
Merge that with your regular excel reader data, which should have the xlsx_row_id exposed.
Then use an AttributeExploder to get one feature per Attribute per row.
