Hi all,
we are company that interested in using FME products. Main issue that we are blocked in current process is DEM generation. We compare results with Civil 3D and failed to tune FME workbench to get comparable quality. As I understood FME has only 2 settings for DEM interpolation: planar and constant. Planar gives us better results, but still interpolation doesn't seem good enough. It is not accurate. Ive attache some synthetic file that we use for quality assurance. And results from FME and Autocad Civil3D. Another question is what should be best input format for such operation, our pipeline set to work with 3d edges, but may be TIN would give better quality? May be anyone solved this task in the past to move process of DEM conversion of TIN from Civil3D to FME?
Here is file that I am working with and results: files . Basically I dont understand why FME give so big difference in elevations and why it is not symmetrical for pyramids.
