Python script to modify output file (ECW image file)
  • Jul 28, 2022 11:07 PM UTC
  • 9 replies
  • 350 views
nicholas
Forum|alt.badge.img+14
How would I build a workspace with an ECW Writer transformer, followed by a Python script that modifies the ECW image file after it has been written?
nicholas
  • Jul 29, 2022 1:08 AM UTC
My progress so far is;
FeatureWriter (instead of Writer) to write the ECW (version 2) file
ListExploder so that count and name are now attributes
AttributeCreator to concatenate _dataset and name to generate the name of the ecw file
PythonCaller
Where I am stuck is the Python to use to explicitly set the values of Datum and Projection in the header of the (version 2) ECW file
nampreetatsafe
PythonCaller
Hi @nicholas​. I think you're on the correct path if you want to use Python. You can also try using a shutdown script to do post-process your ECW using Python. I wondering why the header isn't being populated with the coordinate system info with FME? Have you tried doing the following as daveatsafe suggested here using an EPSG number to define your coordinate system?
Right-click on the output ECW feature type and choose Properties:Screen Shot 2022-06-09 at 3.05In the dialog that opens, set Use EPSG Code for Projection to Always:
Screen Shot 2022-06-09 at 3.05If this isn't working, would you mind sharing a simplified workspace (if you Save As Template, you can package up you source data with your workspace as a .fmwt file) to help demonstrate what's happening?
nicholas
  • Jul 31, 2022 11:54 PM UTC
Hi @nampreetatsafe​, I want to write a version 2 ECW with a CRS of MGA2020-56_FME
The header of the ECW (that FME has written) has two values, one for datum and another for projection
datum: EPSG:1168
projection: SUTM56
When I open this in QGIS, and examine the properties of the layer, QGIS does not recognise the CRS "Coordinate Reference System unknown"
I can manually change the value for projection to EPSG:7856
Then, QGIS does recognise the CRS properly as GDA2020 / MGA Zone 56
So, I am trying to write a python script that will explicitly write the value "EPSG:7856" to the header of the (version 2) ECW
I think that in python I need to;
open the ecw
seek the correct position in the file
close the ecw
But I do not know how to write this properly
nicholas
  • Jul 31, 2022 11:55 PM UTC
I do have a business need for the version 2 ECW.
When I choose version 2, the option to Use EPSG code for projection is not there
nicholas
  • Aug 1, 2022 12:15 AM UTC
Hi @nampreetatsafe​ I have uploaded a fmwt here, as you suggested
nicholas
  • Aug 4, 2022 12:58 AM UTC
Here is the code in my PythonCaller
import fme
import fmeobjects
# Template Function interface:
# When using this function, make sure its name is set as the value of
# the 'Class or Function to Process Features' transformer parameter
def processFeature(feature):
  pass
# Template Class Interface:
# When using this class, make sure its name is set as the value of
class FeatureProcessor(object):
  def __init__(self):
    pass
  def input(self,feature):
    print('start')
    # f = open('G:\\Geospatial\\GIS\\nick\\2022\\07\\ECW\\out\\SW_388000_8012000_1k.ecw', 'wb')
    # f.seek(74,0)
    # f.write('EPSG:7856')
    # f.close()
    print('finish')
    self.pyoutput(feature)
  def close(self):
    pass
I don't know how to make it work. I know I need to open, then seek, then write, then close, but how? How do I open the ECW file?
nicholas
  • Aug 17, 2022 11:50 PM UTC
Hi @nampreetatsafe​ did you look at my fmwt?
danminneyatsaf
Forum|alt.badge.img+13
Hi @nicholas​ if you want the EPSG code to be written out with the file, then you will need to use ECW Version 3 in the Writer parameters. Unfortunately, this setting is not available when using Version 2 in the Writer parameters. Additionally, even writing out with the writer set to Version 3, I can see that EPSG:7856 has not been verified to work with Erdas Products .
If you're looking to edit the ECW file manually, you could try reading the output ECW file in your workspace with the Text File Reader to read the file as raw text, and then use a StringReplacer to replace the EPSG:1168 string with EPSG:7856.
nicholas
  • Aug 26, 2022 3:54 AM UTC
I think I have got it working
Code in PythonCaller
import fme
import fmeobjects
  pass
  def __init__(self):
    pass
    print ('start')
    ecw_path = feature.getAttribute('_dataset')
    ecw_name = feature.getAttribute('name')
    file_name = ecw_path+'\\\\'+ecw_name+'.ecw'
    print ('file')
    print (file_name)
    with open(file_name,'r+b') as ecw_file:
    #  pass
      print('set datum to EPSG:1168')
      datum_string = 'EPSG:1168'
      datum_binary = datum_string.encode()
      ecw_file.seek(57,0)
      ecw_file.write(datum_binary)
      print('set projection to EPSG:7856')
      projection_string = 'EPSG:7856'
      projection_binary = projection_string.encode()
      ecw_file.seek(73,0)
      ecw_file.write(projection_binary)
    print ('finish')
  def close(self):
    pass
