Python libraries run before workbench
  • Sep 21, 2017 2:25 PM UTC
  • 83 views
oliver.morris
Forum|alt.badge.img+14
I am new to using FME cloud, can you please explain how I can install custom python libraries onto FME Cloud and call them before the workbench runs. I would like to drop and create an elasticsearch index before the workbench then goes and populates it.
Many Thanks,
Oliver
The current python code is:
import pyodbc, json
from elasticsearch import Elasticsearch
es = Elasticsearch([{'host': 'search-dev-elasticsearch-z4b7vwlsqswv4uial343rdjccq.us-east-1.es.amazonaws.com', 'port': 443}],use_ssl=True,verify_certs=False)
es.indices.delete(index='productdownloadsdb_full', ignore=[400, 404])
mapping = '''
{    "mappings": {
      "downloads": {
        "properties": {
          "HYPERLINK_PDF": {
            "type": "text"
          "HYPERLINK_ZIP": {
            "type": "text"
          "ID": {
            "type": "integer"
          "PDF_BODY": {
            "type": "text"
          "PDF_FILE": {
            "type": "text"
          "Title": {
            "type": "text"
          "ZIP_FILE": {
            "type": "text"
          "geometry": {
            "type": "geo_point"
es.indices.create(index='productdownloadsdb_full', ignore=400, body=mapping)
Best answer by david_r
Have a look here:
https://knowledge.safe.com/questions/4164/python-libraries-on-fme-cloud.html
Forum|alt.badge.img+63
You can import custom python modules into FME Cloud using these steps
  • Sep 21, 2017 2:40 PM UTC
oliver.morris
  • Sep 21, 2017 2:45 PM UTC
excellent, thank you so much
