[Python] How to read shapefile and excel file in order to display data from the excel file on the dgn file ?
  • August 22, 2014
  • 24 views
I want to choose in Python a shapefile and an excel file and merge them in order to display data from the excel file to the shapefile and have a dgn file as output.
If you want, I already have this one but I have two issues.
- Here the source dataset (parcels.tab) is a MapInfo tab and I want to use a shapefile as input.
- I can't use another MapInfo tab, because I can't change the attribute PARCEL_ID to anoher.
Best answer by takashi
Why Python? I would replace the MAPINFO reader in the existing workspace with a SHAPE reader.
Takashi
  • August 22, 2014
Takashi
