Python Exception : 502 Server Error: Bad Gateway for url
  • Sep 23, 2019 12:26 AM UTC
  • 167 views
This is being raised when using an Esri ArcGIS Portal Service Feature Writer.
24,000 features out of 94,000 are successfully written before this is raised by FME Desktop 2019.1.00
Best answer by bruceharold
Hi, you can try reducing the features per request to avoid the underlying timeout. FeatureWriter badly needs a Rejected port so you can implement retry logic. Also raise a support call with Esri and request advice on this.
bruceharold
Forum|alt.badge.img+20
  • Sep 24, 2019 1:19 PM UTC
bruceharold
  • Sep 24, 2019 1:20 PM UTC
@markatsafe is a Rejected port on the way? Cheers.
  • Sep 24, 2019 9:29 PM UTC
Yes, I'll have to batch it in 20K features per request that seems to work.
