Python Exception : 401 Client Error: Unauthorized for url: https://www.arcgis.com/sharing/rest/portals/self?
  • November 28, 2019
  • 7 replies
  • 63 views
Hi All,
I have an FME workbench which read a feature layer from ArcGIS online and export the information into excel sheet, my workbench is running fine in the desktop without any error but when I published it to FME server some times it’s working and sometimes I got the following error “Python Exception <HTTPError>: 401 Client Error: Unauthorized for url: https://www.arcgis.com/sharing/rest/portals/self?
Please note that I include the AGOL connection when I published my fme, I created a new app for this workbench so my users could run it from their side
I’m using FME 2019
Any Ideas?
Cheers,
Rawan
runneals
Forum|alt.badge.img+22
  • December 2, 2019
Hi @rawansaleh,
What build of FME are you using on Desktop/Server? I believe this was fixed in 19731 and later. Just looking and it looks like we haven't had a 401 for the past 2 months. I have found that this error generally appears when your access token has expired. I suggest that you try to re-authenticate the web connection on FME Server and see if that helps.
Good luck!
rudy_v
  • June 27, 2020
Hi I am getting the same error on FME Server
I have re-authenticate the web connection on FME Server, still fails - Using 2019.2.3.2
Rudy
  • March 15, 2021
I'm facing the same issue. I'm using the FME latest version and have re-authenticated the connection, but still returns same the error. Is there other solution can be done to resolve this issue?
siennaatsafe
Forum|alt.badge.img+11
aafirah wrote:
Hi @aafirah​ ,
Have you configured the OAuth connection in FME Server? This should allow FME Server to refresh your connection.
The instructions to do this can be found in my comment here: https://community.safe.com/s/question/0D54Q000080hYdzSAE/how-do-i-reliably-connect-fme-server-201819-to-arcgis-online
If you are still having issues with this could you submit a support case? https://community.safe.com/s/submit-case
gboquin
Forum|alt.badge.img+5
  • April 1, 2021
@siennaatsafe​ @aafirah​ @rudy_v​ @runneals​ @rawansaleh​
I was having the same issue for one of my clients. This is what I did to solve the issue:
  • I created another app in AGOL-- I also added the URI to reference FME server on the app.
  • Updated the client and secret info on web connection-- I was on FME server at this point.
  • Opened the workbench and republished to FME Server.
This is not ideal but it worked for me.
mark_zl
  • July 18, 2021
I'm having the same issue. Is there a fix? I have authenticated a connection but get a similar error.error
mark_zl
  • July 18, 2021
Solved the problem, we logged in as the server user and authenticated the AGOL connection and it now works.
