Python Caller - reading in gpkg file
  • Aug 19, 2025 4:18 AM UTC
  • 5 replies
  • 199 views
hannah-jk
Hello,
I’m using a Python Caller in an FME workspace. In the python script I’m trying to read in a gpkg file using the code below:
import geopandas as gpd
import pandas as pd
import os
def FeatureProcessor(feature):
    path_gpkg = feature.getAttribute('path_gpkg')
    print(path_gpkg)
    print("file exists - ", os.path.exists(path_gpkg))
    gdf = gpd.read_file(path_gpkg)
However, I get an error saying:
Python Exception <DataSourceError>: '/xxx/abc.gpkg' does not exist in the file system, and is not recognized as a supported dataset name.
It is strange because the line ‘print("file exists - ", os.path.exists(path_gpkg))’ returns True.
Has anyone come across anything similar?
lambertus
Forum|alt.badge.img+25
  • Aug 19, 2025 7:20 AM UTC
​@hannah-jk you could try to read the gpkg with a standard FeatureReader to check whether that works?
If so then the PythonCaller should be tuned to read it as well 🙂
Forum|alt.badge.img+54
  • Aug 19, 2025 8:05 AM UTC
How are you setting the attribute path_gpkg?
If you hardcode the path in the python does it make any difference?
e.g. path_gpkg = r"C:/Temp/gpkgtest.gpkg"
Have you tried with backslashes instead of forward slashes?
hannah-jk
  • Aug 22, 2025 3:04 AM UTC
Thanks for the suggestion - using a feature reader does work but reading in the file via a python caller doesn’t work.
hannah-jk
  • Aug 22, 2025 3:24 AM UTC
Thanks - I’ve tried both those suggestions but they don’t work
lambertus
  • Aug 22, 2025 7:07 AM UTC
​@hannah-jk for these kind of things I often use Chat GPT. GPT produced this script:
import os
def processFeature(feature):
    # Get the input attribute with the path to the GPKG
    if not path_gpkg:
        feature.setAttribute('gpkg_status', 'No path provided')
        return feature
    if not os.path.exists(path_gpkg):
        feature.setAttribute('gpkg_status', f'File not found: {path_gpkg}')
        return feature
    try:
        # Read the geopackage with GeoPandas
        # Set some useful info back into FME attributes
        feature.setAttribute('gpkg_status', 'Loaded successfully')
        feature.setAttribute('gpkg_feature_count', len(gdf))
        feature.setAttribute('gpkg_crs', str(gdf.crs))
    except Exception as e:
        feature.setAttribute('gpkg_status', f'Failed to read: {e}')
    return feature
Be aware:
  1. By default, FME’s bundled Python won’t have GeoPandas installed.
  2. You’ll need to configure FME to use an external Python environment where geopandas, fiona, and shapely are installed, this can be achieved using a pip command in your CMD window.
  3. Make sure the variable 'path_gpkg' is available as an attribute in your workspace pointing to your gpkg. You could also replace this with the hardcoded file location or use File and Pathname Reader.
