Published parameter as identity field name does not resolve in feature writer
  • Mar 4, 2020 4:43 PM UTC
  • 0 replies
  • 22 views
ridleyj
Forum|alt.badge.img+8
Using a published parameter such as $(outputTableName) in a SQL writer to name a field.
Taking the parameter value to name the identity field as in $(outputTableName)UKID resolves and creates the column no problem when using a standard SQL writer. So, setting the parameter value to "MyOutputTable" results in a field name of "MyOutputTableUKID".
When attempting to do the same in a SQL FEATURE writer, the parameter will not resolve, and the column is created with the explicit string value '$(outputTableName)UKID'.
Is this behaviour expected between the two varieties of writer?
